poI3DViewCtrl GetPrincipalPointOffset
Gets the principal point offset of a stored view.
poI3DViewCtrl_handle GetPrincipalPointOffset name
HyperView Tcl Query
This command retrieves a string consisting of an x and y offset. These values represent a shift of the view horizontally and vertically in the window.
name
If specified, the offset of the view with that name will be returned. Otherwise, the current view’s offset will be returned.
Get the principal point offset of a view named “View 1”:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetViewControlHandle view_handle
view_handle GetPrincipalPointOffset “View 1”
hwi CloseStack
Error
Returns HW_InvalidHandle if the view handle is invalid.
Returns HW_InvalidArgs if the named view does not exist.
