hwISession SetXMLImageLinkMode
Sets whether the images in the exported PowerPoint file have embedded links.
hwISession_handle SetXMLImageLinkMode use_links
HyperWorks Tcl Modify
This command sets whether images in the exported PowerPoint file (XML or XML_2007) are embedded or linked images.
use_links
The input is true or false.
true
If you want the images in the exported PowerPoint file to be embedded or linked images.
false
If you do not want to have embedded or linked images.
hwi GetSessionHandle sess;
sess SetXMLImageLinkMode true;
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
Modify
