Zooms the plot to within the given dimensions.
Zooms into the dimensions of the curve in the plot.
Makes the given dimensions the center of the plot and changes the axes accordingly.
Moves the axes up, down, left or right based on the increments input.
ON THIS PAGE
ON THIS PAGE
