Gets the frame rate used when exporting AVI files.
Gets the palette used when exporting AVI files.
Gets the relative size (in percent) used when exporting AVI files.
Sets the frame rate used when exporting AVI files.
Sets the palette used when exporting AVI files.
Sets the relative image size (in percent) used when exporting AVI files.
