hwISession SaveSessionFile
Writes the session to the given filename.
hwISession_handle SaveSessionFile filename, savealldata
HyperWorks Tcl Modify
filename
The session file to be written.
savealldata (Optional)
Allows you to save all the data in the session file as opposed to only references to the data.
To save the current session as a report template to "myfile":
mySessionName SaveReportTemplate myfile
Error
Success (0) or an error code.
