hwISession GetCurrentClient
Returns the name of the active client.
hwISession_handle GetCurrentClient filename
HyperWorks Tcl Query
Returns the name of the active client or an empty string if an error occurs. The possible client names are determined by which clients are loaded.
filename
The name of the active client.
To get the name of the active client:
mySessionName GetCurrentClient
Error
Success (0) or an error code.
