hwISession IsClientLoaded
Indicates whether or not the specified client type is available in the current session.
hwISession_handle IsClientLoaded client_name
HyperWorks Tcl Query
Returns true if the requested client is loaded; false otherwise.
client_name
The name of the client for which you are querying.
To determine if the "Plot" client is loaded in the current session:
mySessionName IsClientLoaded Plot
None.
