hwISession RegisterExternalFunction
Registers the given external function.
hwISession_handle RegisterExternalFunction filename, function_name, num_arguments
HyperWorks Tcl Query
filename
The name of the dll or shared object file to be registered.
function_name
The name of the function.
num_arguments
The number of arguments.
To export the contents of the current session to an HTML or XML report:
mySessionName PublishSession myReportName 20
Error
Success (0) or an error code.
