HM_vectormagnitude()
Calculates the magnitude of a vector.
int HM_vectormagnitude(HM_vectorpointer vector);
HyperMesh hmlib Function
vector
A pointer to a vector.
If successful, the function returns zero; otherwise, nonzero.
This function calculates the magnitude of a vector using the "dist" portion of the vector structure. After the function is called, the "unit" and "magnitude" portion of the vector structure is set to values that represent the unit vector and magnitude of "dist."
None.
