HM_vectorfromthreepoints()
Calculates a vector defined by three points.
int HM_vectorfromthreepoints(HM_vectorpointer vector, double point1[3], double point2[3], double point3[3]);
HyperMesh hmlib Function
vector
A pointer to a vector where the result of the cross product should be stored.
point1[3]
A point in space; base of resultant vector.
point2[3]
A point in space.
point3[3]
A point in space.
If successful, the function returns zero; otherwise, nonzero.
This function calculates the vector formed by crossing the vector formed from *point1 to *point2, and the vector formed from *point1 to *point3.
None.
