hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Allocates a block of memory and clears it to zero.
Frees a block of memory.
Allocates a block of memory.
Reallocates a block of memory.
