hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Reads an end of line from an ASCII file.
Reads a fixed double from an ASCII file.
Reads a fixed integer from an ASCII file.
Reads a fixed string from an ASCII file and stores it in the location pointed to by the user-passed character pointer string.
ON THIS PAGE
ON THIS PAGE
