Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration
point results or node-on-element results.
For an element configuration, this function returns the number of nodes that the element uses. For rigidlinks and RBE3s,
this function returns 0 because these elements have a variable number of nodes.
HM_elementconfiggetnumberofnodes()
For an element configuration, this function returns the number of nodes that the element uses. For rigidlinks and RBE3s, this function returns 0 because these elements have a variable number of nodes.
HM_entitynamegettype()
Returns the HyperMesh #defined type number of an entity, given its name.
HM_entitytypegetname()
Returns the name of an entity, given the HyperMesh #defined type number.
