HM_asciifile_readfixedint()
Reads a fixed integer from an ASCII file.
int HM_asciifile_readfixedint(FILE * file, int width);
HyperMesh hmlib Function
Reads a fixed integer from an ASCII file. Returns the value of the integer contained in the field.
file
The handle to the open ASCII file (must be opened with fopen("","rt")).
width
The width of the integer that should be read.
None.
