HM_asciifile_readfixeddouble()
Reads a fixed double from an ASCII file.
double HM_asciifile_readfixeddouble(FILE * file, int width);
HyperMesh hmlib Function
Reads a fixed double from an ASCII file. Returns the value of the double contained in the field.
file
The handle to the open ASCII file (must be opened with fopen("","rt")).
width
The width of the real number that should be read.
None.
