HM_calloc()
Allocates a block of memory and clears it to zero.
void * HM_calloc(int n, int size);
HyperMesh hmlib Function
n
The number of items to be stored in the block.
size
The size of the items.
If successful, HM_calloc()returns a pointer to the block of memory. If unsuccessful, HM_calloc()calls HM_terminate() with an appropriate error message, and program execution is terminated.
None.
