HM_malloc()
Allocates a block of memory.
void * HM_malloc(int size);
HyperMesh hmlib Function
size
The size of the wanted block in bytes.
If successful, HM_malloc()returns a pointer to the block of memory. If unsuccessful, HM_malloc() calls HM_terminate() with an appropriate error message, and program execution is terminated.
None.
