HM_nodeprojecttoplane()
Projects a node to a plane along a vector.
int HM_nodeprojecttoplane(double node[3], HM_planepointer plane, HM_vectorpointer vector);
HyperMesh hmlib Function
node[3]
The nodal position to be projected. This variable is overwritten with the result of the projection.
plane
The plane to which the node is to be projected.
vector
The vector along which the node is to be projected.
If successful, HM_nodeprojecttoplane() returns zero; otherwise, nonzero.
None.
