HM_strnicmp()
Performs a string compare, ignoring upper and lower case.
int HM_strnicmp(const char *string1, const char *string2, size_t n)
HyperMesh hmlib Function
string1
A pointer to the first string you want to compare.
string2
A pointer to the second string you want to compare.
n
The number of characters in the strings to compare.
-1, if string1 < string2
1, if string1 > string2
0, if string1 = string2
None.
