HM_strinsc()
Inserts a character into a string.
char * HM_strinsc(char * string, int position, char character);
HyperMesh hmlib Function
string
A pointer to a string that is to have a character inserted.
position
The position in the string at which the character should be inserted.
character
The character to be inserted.
A pointer to the string.
None.
