HM_strins()
Inserts a string into another string.
char * HM_strins(char * string1, int position, char * string2);
HyperMesh hmlib Function
string1
A pointer to the string that is to have string2 inserted.
position
The position in *string1 where *string2 should be inserted.
string2
A pointer to the string that is to be inserted into *string1.
A pointer to the string.
None.
