Toolbars Tab
The Toolbars tab allows you to select/change the toolbar types that are displayed in the Results Browser.
The options that are available depend upon the currently selected view mode.
Figure 1. Toolbars Tab on the Browser Configuration Dialog
The following toolbar types are available for display:
  • Change load case
  • Change model
  • Find/Filter
  • To select toolbar types manually, activate the check boxes next to each desired toolbar. A check mark indicates that the toolbar type will display in the browser.
  • You can also use the Select All, Select None, and Select Reverse buttons in this mode.
