Entities Tab
The Entities tab allows you to select/change the entity types that are displayed in the Results Browser.
The options that are available depend upon the currently selected view mode.
Figure 1. Entities Tab on the Browser Configuration Dialog
  • To select entity types manually, activate the check boxes next to each desired entity type. A check mark indicates that the entity type will display in the browser.
  • You can also use the Select All, Select None, and Select Reverse buttons in this mode.
