HyperView Toolbars
The HyperView toolbars provide you with quick access to some of the most commonly used panels and tools.
The following toolbars are available:
  • Annotations
  • Display
  • Results
  • Tools
  • Visualization
  • Visibility Controls
From the View menu, select Toolbars > HyperView and then click on a toolbar name to turn the display on/off for the selected toolbar.
All of the HyperView toolbars are dockable (meaning they can be positioned anywhere within the window by dragging them with your mouse).
Note: Animation files are loaded using the Load Model panel. To access the Load Model panel, click Open Model on the Standard toolbar, or from the File menu select Open > Model.
