Visualization Toolbar
The Visualization toolbar provides you quick access to the Entity Attributes and Exploded View panels, and also allows you to set and apply the current element visualization mode to the entities on the model.
Figure 1. Visualization Toolbar
To access each panel or set/modify/apply the element visualization mode, click the corresponding button on the toolbar:
Button Panel/Element Visualization Mode/Dialog Description
Opens the Entity Attributes panel. Settings such as component color, mesh lines, shading, transparency, and entity display options are available in the multi-body dynamics (MBD) results.
Color By mode (Component, Model, Normal, or Part). Use the drop-down menu to change the color by mode to:
Component
Set the current color by mode to Component.
Model
Set the current color by mode to Model. Model color can be set in the Files View of the browser.
Normal
Set the current color by mode to Normal. A positive normal side will be displayed in red and a negative normal side of an element will be displayed in blue. This mode is applicable only to shell elements. Other types of elements will be shown in gray.
Part
Set the current color by mode to Part.
Wireframe Elements (default)
Set the current element visualization mode to Wireframe Elements. Internal and surface mesh lines display.
To change the element visualization mode, left-click the lower right arrow to expand the Options menu.
Transparent Elements and Feature Lines
Set the current element visualization mode to Transparent Elements and Feature Lines. Elements are shaded but transparent, no mesh lines display, however feature lines do.
Left-click the lower right arrow to expand the Options menu.
Shaded Elements and Mesh Lines (default)
Set the current element visualization mode to Shaded Elements and Mesh Lines. Elements are shaded and surface mesh lines display.
Shaded Elements and Feature Lines
Set the current element visualization mode to Shaded Elements and Feature Lines. Elements are shaded but have no mesh lines, while feature lines display.
Shaded Elements
Set the current element visualization mode to Shaded Elements. Elements are shaded, but no lines display.
Opens the Exploded View panel. Explode a model for better visualization. You can also create, delete, and save customized exploded views.
Opens the Symmetry Dialog dialog. Define options which can be used to visualize what a whole model would look like when you are modeling only a half, quarter, or a partial segment or as axisymmetric.
Opens the Sets panel. Create, import, and export sets/groups of components, elements, and nodes into HyperView. You can also import Animator3 session files and LSPost group files into HyperView.
Note: There is no right-click behavior for the icons listed above.
