Tools Toolbar
The Tools toolbar provides you quick access to the Add Object, Collision Detection, and FLD panels.
Figure 1. Tools Toolbar
To access each panel, click the corresponding button on the toolbar:
Button Panel Description
Opens the Add Object panel. Add an object to a specific graphic component or modify an existing object.
Opens the Collision Detection panel. The Collision Detection panel can be used to demonstrate collision interference checking.
Opens the FLD panel. Plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
Note: There is no right-click behavior for the icons listed above.
