Options Tab
The Options tab allows you to select/change the global options for all browsers.
Figure 1. Options Tab on the Browser Configuration Dialog
  • To select entity types manually, activate the check boxes next to each desired entity type. A check mark indicates that the entity type will display in the browser.
  • You can also use the Select All, Select None, and Select Reverse buttons in this mode.
Autofit
Automatically fit the selected items to the modeling window, whether using the context menu or the Selector, Show/Hide, or Isolate functionality to control the display.
Autoscroll on selection
Locate/highlight an item in the browser and automatically adjust the browser tree to display the item upon selection. This functionality is only available when an item has been selected via the Selector functionality in the modeling window.
If this option is not activated, then the item will still be located/highlighted in the browser; however, the browser tree will not automatically adjust to show the selected item.
