Find/Filter
The Find/Filter toolbar contains search options that can be used to locate an entity within the browser's tree structure.
The Find/Filter option is located on the Toolbars tab in the Browser Configuration window. This opens a field in the browser where you can enter in a search string to find and filter entities.
You can configure the toolbar visibility by using the context menu. Select Configure Browser and go to the Toolbars tab. Toggle on/off the Find/Filter toolbar by clicking the Find/Filter check box.
