Change Load Case
The Change load case toolbar allows you to change the current load case/simulation.
The current load case/simulation is displayed in this toolbar, however you can use the drop-down menu to make another selection from the list. You can also use the arrow up/down buttons to conveniently step through the available load cases/simulations.
You can configure the toolbar visibility by using the context menu. Select Configure Browser and go to the Toolbars tab. Toggle on/off the model toolbar by clicking the Change load case check box.
