Change Model
The Change model toolbar allows you to change the current model.
The current model is displayed in this toolbar, however you can use the drop-down menu to make another selection from the list. You can also use the arrow up/down buttons to conveniently step through the available models.
You can configure the toolbar visibility by using the context menu. Select Configure Browser and go to the Toolbars tab. Toggle on/off the model toolbar by clicking the Change model check box.
