Skin Effect and Ohmic Losses
Specify the skin effect through the high frequency, static or exact expression.
High frequency approximation skin effect
The required parameters are , and (defined with the DI card). If applied to surfaces then also the thickness d is required.
- A good conductivity is required, satisfying the condition .
- For wires the skin depth must satisfy the condition where is the wire radius. The surface impedance is given by .
- For metallic surfaces the skin depth must satisfy the condition . The surface impedance is given by .
Static approximation skin effect
Exact expression for the skin effect
- For wires with wire radius
the surface impedance is given bywhere J0 and J1 are Bessel functions.
(1) - For a sheet of thickness, d, with properties
with
the wave propagation constant in the sheet is given by
and the wave impedance in the sheet by
. The reflection coefficient at the interface between the
sheet and the environment is defined as
(2)
