OM Card
This card can be used to calculate the weighted set of orthogonal current-modes which are supported on a conducting surface.
On the Request tab, in the Configurations
group, click the
Characteristic modes icon.
Figure 1. The OM - Characteristic mode analysis dialog.
Parameters:
- Request name
- The name of the request.
- Number of modes to calculate
The maximum number of modes to calculate for the characteristic mode analysis.
- Compute modal excitation coefficients
- When this item is checked, in addition to the characteristic modes, modal excitation coefficients are computed given an excitation/source.
- Disable mode tracking
- When this item is checked, characteristic mode tracking is disabled. This means that for each frequency, the modes will be sorted according to their dominance at that frequency. When unchecked, a logical mode will be tracked over the entire simulated frequency range.
The characteristic mode analysis (CMA) is supported for MoM/SEP examples containing dielectric and magnetic materials and metallic structures, such as metallic triangles and wires. CMA can also be used in conjunction with the planar multilayered Green’s function as well as the planar Green’s function aperture. No VEP, waveguide ports, MLFMM or FEM are allowed in conjunction with a characteristic mode analysis request.
