MD Card
This card exports the model and solution coefficients to a .sol file.
On the Request tab, in the Solution requests
group, click the Model decomposition
(MD) icon.
Figure 1. The MD - Options for model decomposition dialog.
A .sol file can be used to specify an impressed current source (AM card).
Parameters:
- Remove all previously defined model decomposition options
- All previously defined model decomposition options are removed.
- Model name
- The name of the model.
- Include all structures
- Model decomposition is done for all structures.
- Include structures with specified labels(s)
- Model decomposition is only done for structures with specified labels.
- Include structures with label range
- Model decomposition is only done for structures with a label in the range specified in the fields Start at label and End at label.
- Calculate solution coefficients in local coordinate system
- Use the offset specified below as the origin of the coordinate system for model decomposition.
- Origin of offset coordinate
- In this group the Cartesian coordinates of the transformed origin are specified. Each of X, Y and Z is scaled by the SF card if the SF card is used.
- Rotation about the axis
- The angle of rotation around the X axis, the angle of rotation around the Y axis and the angle of rotation around the Z axis in degrees.
