KS Card
The KS card facilitates the transferral of signal names from CADFEKO to POSTFEKO.
On the Solve/Run tab, in the Cables group, click the  Signals (KS) icon.
Figure 1. The KS - Cable signal label dialog.
Parameters:
Corresponding cable section
The label of the CS card that links to this KS card.
Define cable signals on a cable section
Define cable signals on a cable section with the following parameters.
Remove all cable signals previously defined
This KS card does not define a cable signal, but rather all previously defined cable signals are deleted. All the other input parameters of this card are ignored.
Number of signals
The number of signals being defined. It should correspond to the number of signals/connections for the respective cable instance.
