User Defined Surface Impedance
This option allows the definition of a complex user defined surface impedance, Zs.
Figure 1. The SK - Add a skin effect (finite conductivity) dialog.
Parameters:
- Material label
- Label of the material which will be used as the defined surface impedance (as specified in the DI card).
For example, to model a solid dielectric object with relative permittivity and with conductivity at a specific angular frequency the following surface impedance expression can be used:
The user defined complex surface impedance Zs relates to the surface current Js and the E-field by where is the tangential E-field and is the surface current density.
