Reference: String
Model ElementReference_String defines a user defined text string in MotionSolve. The string may be of any length. It must contain only printable ASCII characters.
Reference_String is primarily used within user defined subroutines. They are commonly used to pass filenames, messages, block names and DLL names to user defined subroutines.
Within a user defined subroutine, the MotionSolve utility subroutine GTSTRG is used to access the Reference_String. The ID of the Reference_String itself may be passed as a parameter to the user defined subroutine.
<Reference_String
  id                  = "ID Number"
  label               = "Name of the string"
  string              = "The string itself" >
  usrsub_dll_name     = valid_path_name
  usrsub_param_string = "USER([[par_1[,...][,par_n]])"
  usrsub_fnc_name     = "custom_fnc_name" >
  script_name         = valid_path_name
  interpreter         = "PYTHON" | "MATLAB"
Attributes
id
Element identification number (integer>0). This number is unique among all Reference_String elements.
label
The name of the Reference_String element.
string
Specifies the character string to be stored.
usrsub_dll_name
Specifies the path and name of the DLL or shared library containing a user subroutine. MotionSolve uses this information to load the user subroutine in the DLL at run time.
usrsub_param_string
The list of parameters that are passed from the data file to the user defined subroutine, String_Read. This attribute is common to all types of user subroutines and scripts.
usrsub_fnc_name
Specifies an alternative name for the user subroutine String_Read.
script_name
Specifies the path and name of the user written script that contains the routine specified by usrsub_fnc_name.
interpreter
Specifies the interpreted language that the user script is written in. Valid choices are MATLAB or PYTHON.
The example below demonstrates how a Reference_String can be used to define a filename that can be passed to a VARSUB. Notice how the ID of the Reference_String is passed as a parameter to the user defined VARSUB. This generalizes the implementation of the VARSUB.
<Reference_String
   id                  = "1101"
   label               = "Name of string"
   string              = "/staff/gates/test/tire_data.xml" >
Reference_Strings may be used in any user defined subroutine.
