Parameters: Transient Solver
Model ElementParam_Transient defines the simulation control parameters for a time-domain-based nonlinear dynamic analysis.
- The choice of the integrator.
- The integration error tolerance (or the accuracy of the solution).
- Integrator performance during the simulation.
Dynamic simulations are performed on systems with one or more degrees of freedom. The dynamic simulation accounts for all inertia effects, all applied forces, and internal constraints. This enables you to run accurate system level simulations of complex mechanical systems.
- The Ordinary Differential Equations (ODE) form of the equations.
- The Differential Algebraic Equations (DAE) form of the equations.
The settings for each formulation are documented separately.
ODE Form | DAE Form |
<Param_Transient
[ integrator_type = "string" ] [ integr_tol = "real" ][ h_max = "real" ] [ h0_max = "real" ][ vel_tol_factor = "real" ] [ max_order = "integer"][ rel_abs_tol_ratio = "real" ] /> |
<Param_Transient
[ integrator_type = "string" ] [ integr_tol = "real" ][ h_max = "real" ] [ h_min = "real" ][ h0_max = "real" ] [ vel_tol_factor = "real" ][ max_order = "integer"] [ dae_alg_tol_factor = "real" ][ dae_index = "integer"] [ dae_constr_tol = "real" ][ dae_corrector_maxit = "real" ] [ dae_corrector_minit = "real" ][ dae_vel_ctrl = "TRUE|FALSE"] [ dae_jacob_eval = "integer"][ dae_eval_expiry = "integer"] [ dae_jacob_init = "integer"][ dae_interpolation = "TRUE|FALSE"] /> |
Attributes (ODE)
- integrator_type
- Defines the integrator to be used with the ODE form of the equations of
motion. Select one of the following:
- VSTIFF
- MSTIFF
- ABAM
- integr_tol
- Represents the maximum absolute error per step that the integrator is allowed in computing the displacement, velocity, and differential equations states. Differential equation states include those found in <Control_Diff>, <Control_SISO> and the <Control_StateEqn> modeling entities.
- h_max
- Defines the maximum step size the integrator is allowed to take. You can also use this parameter to control the accuracy of the results. Generally, a smaller time step leads to more accurate results. For models with discontinuities, such as contact, a smaller value of h_max should be specified. Note that the maximum integrator step size is set to the print_interval in the Simulate command if the print_interval is smaller than h_max.
- h_min
- Defines the minimum step size the integrator is allowed to take.
- h0_max
- The maximum initial step size. The default value for h0_max is 1.0E-8.
- vel_tol_factor
- A factor that multiplies integr_tol to yield the error tolerance for velocity states.
- rel_abs_tol_ratio
- The factor that multiplies integr_tol to yield the relative error tolerance for the integrator.
- max_order
- Specifies the maximum order that the integrator is to take. Each
integrator has its own built-in maximum order. Higher orders lead to
higher accuracy, but lower stability in the numerical method. The
table below shows the maximum order for the various integrators in
MotionSolve that work with the ODE
- Integrator
- Maximum Order
- ABAM
- 12
- VSTIFF
- 05
- MSTIFF
- 09
Attributes (DAE)
- integrator_type
- Defines the integrator to be used with the DAE form of the equations of motion. Currently, only one DAE integrator is supported - DSTIFF.
- integr_tol
- Represents the maximum absolute error per step the integrator is allowed in computing the displacement, velocity, and differential equations states. Differential equation states include those found in <Control_Diff>, <Control_SISO>, and the <Control_StateEqn> modeling entities.
- h_max
- h_min
- h0_max
- vel_tol_factor
- The factor that multiplies integr_tol to yield the error tolerance for velocity states.
- max_order
- Specifies the maximum order that the integrator is to take. Higher orders lead to higher accuracy, but lower stability in the numerical method. The default maximum order for DSTIFF is 5.
- dae_alg_tol_factor
- The factor that multiplies integr_tol to yield the error tolerance for algebraic states like Lagrange Multipliers.
- dae_index
- The index of the DAE formulation.
- dae_constr_tol
- The tolerance on all algebraic constraint equations that the corrector must satisfy at convergence.
- dae_corrector_maxit
- The maximum number of iterations that the corrector is allowed to take to achieve convergence.
- dae_corrector_minit
- The minimum number of iterations that the corrector is allowed to take before it checks for corrector divergence.
- dae_vel_ctrl
- The logical flag that controls whether the velocity states are checked
for local integration error at each step. This is only valid for the
SI1 integrator (see dae_index).
- "TRUE" indicates that the integrator is to include velocity states in its check for local integration at the end of each step.
- "FALSE" indicates that the integrator is to exclude velocity states in its check for local integration at the end of each step.
- dae_jacob_eval
- This attribute controls the frequency of evaluation of the Jacobian
matrix during corrector iterations.
- 0
- Implies that the integrator automatically determines when a new Jacobian is needed by examining the rate of convergence.
- 1
- Implies that a new Jacobian is to be calculated at every iteration.
- 2
- Implies that a new Jacobian is to be calculated at every other iteration, for example at iteration 1-3-5, and so on.
- 3
- Implies that a new Jacobian is to be calculated at every third iteration, for example at iterations 1-4-7, and so on.
- dae_eval_expiry
- This is an optional attribute. It defines the number of integration steps after which the evaluation pattern defined by dae_jacob_eval is ignored, and the default evaluation pattern is to be used. The default evaluation pattern is automatically determined when a new Jacobian is needed by examining the convergence rate of the corrector.
- dae_jacob_init
- This attribute specifies the number of initial Jacobian matrix
evaluations during corrector iteration.
- 0
- 1
- Implies that a new Jacobian is to be calculated at the first iteration and none afterward.
- 2
- Implies that a new Jacobian is to be calculated at the first and second iterations, none afterward, as so on with higher values of this setting.
- dae_interpolation
- Specifies whether the integrator uses interpolation for the results at
the output steps.
- TRUE means that MotionSolve interpolates (as needed) the results at the output points requested by the user.
- FALSE means that MotionSolve uses the DASPK integrator to interpolate (as needed) the results at the output points requested by the user.
- Numerical and Physical Stiffness
Numerical stiffness is quite different from "physical" stiffness. Numerical stiffness is governed by the damping characteristics of a system, whereas physical stiffness is governed by the stiffness intrinsic to the system (for example, a spring in the system). The concept of numerical stiffness is quite closely related to the eigenvalues of the system at an operating point.
The eigenvalues of a system have two components: the real part and the imaginary part. The real part defines the damping characteristics of the system and the imaginary part defines the vibration frequencies of the system at the operating point.
- An eigenvalue with no imaginary component defines an over-damped vibration mode.
- An eigenvalue that has no real component defines an undamped vibration mode.
- A complex eigenvalue defines an under-damped vibration mode.
A numerically stiff system is characterized by widely separated eigenvalues that exhibit the following properties:
- The high frequency components are over-damped and rapidly decay.
- The low frequency components of the solution exhibit under-damped
behavior.
The concept of numerical stiffness is explained using the simple example shown below.
The figure below depicts two unconnected spring-mass systems. The first system has a mass M1 supported by a spring with properties K1, C1 and L01. The second system has a mass M2 supported by a spring with properties K2, C2 and L02. The displacement of mass M1, measured with respect to a global coordinate system, is denoted as x1. The displacement of mass M2, measured with respect to a global coordinate system, is denoted as x2.
Assume:- M1=1Kg, C1=2 N sec/m and K1=104 N/m
- M2=1Kg, C2=2x104 N sec/m and K2=108 N/m
Figure 1. Two Unconnected, Simple Spring-mass SystemsFor each system, i, the following are easily ascertained:- The equation of motion for system-i is:
(1) - The eigenvalues for system-i are:
(2) - The eigenvalues and response for the first system is:
(3) - The eigenvalues and response for the second system is:
(4)
System 1 is under-damped. It will display decaying oscillations in response to an initial disturbance. After 0.01 seconds, the initial disturbance is reduced by a factor = e-0.01 = 0.99 of the original value. System 1 oscillates at a frequency of 99.995 radians/sec.
In contrast, system 2 is over-damped. After 0.01 seconds, the initial disturbance is reduced by a factor = e-100 = 3.72 x 10-44 of the original value. For any initial disturbance, system response is almost instantaneously damped out. System 2 does not oscillate at all.
A system exhibiting these characteristics is called numerically stiff. One component of the solution exhibits slow decay to an initial excitation whereas another component rapidly dies almost instantaneously.
Many mechanical systems have numerically stiff properties or are characterized by differential-algebraic equations (see comment 2). These can only be solved efficiently by a stiffly-stable integrator.
- Differential Algebraic Equations
A system of equations, which is a combination of ordinary differential equations, and algebraic constraint equations are called differential algebraic equations.
Figure 2. A Multi-body system.For example, in a multi-body system (MBS), Newton's second law manifests itself in the form of second order, ordinary differential equations (ODE) while constraints in the system (joints, for example) manifest themselves as algebraic equations (AE). Hence, the mathematical representation of a typical multi-body system is a system of differential algebraic equations. The mechanism shown in the figure above is usually characterized by differential algebraic equations.
Ordinary differential equations are represented as:(5)
y are the states to be integrated
Differential algebraic equations are represented as:
(6)
- Index of a DAE
The index of a system of DAEs is defined as the number of times you need to differentiate the constraints in the system with respect to the independent variable (usually time), to get a system of ordinary differential equations. This is illustrated in the figure below.
Figure 3. Index of a system of DAEs. - Equation FormulationMotionSolve supports four different equation formulations for dynamic simulations:
- The ODE formulation
- The ODE formulation supports both stiff and non-stiff integrators. MotionSolve transforms the DAE form equations of motion into ODE form equations using coordinate partitioning and then solves the resulting equation using an ODE integrator. Both stiff and non-stiff integrators are supported. The stiff integrators supported by this formulation are (a) VSTIFF and (b) MSTIFF. The integrator ABAM is used to integrate non-stiff solutions.
- The DAE Index-3 (I3) formulation
- The I3 formulation provides the DAE form of the equations of motion to an integrator capable of solving this form of the equations of motion. DSTIFF is the only integrator in MotionSolve capable of solving the I3 form of the equations of motion. In the I3 formulation, the integrator does not monitor the integration local error in the velocity states. Consequently, I3 solutions typically tend to be very fast, though slightly inaccurate in velocities sometimes.
- The DAE Stabilized Index-1 (SI1) formulation
- The SI1 formulation provides an even more "stabilized" index-1 DAE form of the equations of motion to an integrator capable of solving this form of the equations of motion. The term "stabilized" refers to the seemingly redundant set of velocity and acceleration constraints that are added to the I3 set. These enforce consistency of velocities and accelerations with the velocity and acceleration constraints - which would be automatic if the solutions were exact. DSTIFF is the only integrator in MotionSolve capable of solving the SI1 form of the equations of motion. In the SI1 formulation, the integrator monitors the integration local error in both the displacement and velocity states. Consequently, SI1 solutions typically tend to be very accurate. The typical speed of SI1 solutions, compared to I3 solutions, is somewhat slower.
- Numerical SolutionMotionSolve provides four different integration algorithms for dynamic simulations.
- DSTIFF
- This is the default integrator in MotionSolve. This code solves a system of differential/algebraic equations of the form G(t,y,y') = 0, using a combination of Backward Differentiation Formula (BDF) methods. This is based on the publicly available integrator DASPK. The authors of this integrator are Linda R. Petzold, Peter N. Brown, Alan C. Hindmarsh, and Clement W. Ulrich. It was developed at the Lawrence Livermore National Laboratory (LLNL) and subsequently at the University of California, Santa Barbara. This integrator is only available for the DAE forms of the equations of motion (I3 and SI1) in MotionSolve.
- VSTIFF
- This is a stiffly stable, fixed-leading coefficient, BDF integrator based on VODE. VODE was developed by P.N. Brown (Lawrence Livermore National Laboratories [LLNL]), G.D. Byrne (SMU), and A.C. Hindmarsh (LLNL). This is the default stiff integrator for the ODE form of the equations of motion in MotionSolve. VODE solves the initial value problem for stiff or non-stiff systems of first order ODEs of the form dy/dt = f(t,y), or, in component form, dyi/dt =fi(t,y1,y2,...,yNEQ) (i = 1,...,NEQ).
- VODE
- A package based on the EPISODE and EPISODEB packages, and on the ODEPACK user interface standard, with minor modifications.
- MSTIFF
- This is a stiffly stable, BDF integrator based on the Modified Extended Backward Differentiation Formulae (MEBDF), developed by J R Cash. This integrator is only available for the ODE form of the equations of motion in MotionSolve.
- ABAM (Adams-Bashforth-Adams-Moulton)
- This is a non-stiff integrator, written by Laurence F. Shampine and Marilyn K. Gordon. This integrator is only available for the ODE form of the equations of motion in MotionSolve.
- Index-3 DAE form of the Equations of MotionAssume that a system is defined as follows:
- "N" displacement coordinates q=[q1, q2, … qN]T are used to represent the system.
- The coordinates q are not all independent.
- "M" displacement constraints Φ =[ Φ1(q,t), Φ2(q,t), … ΦM(q,t)]T exist between the "N" coordinates q.
- Let λ = [ λ1, λ2 … λM]T represent Lagrange Multipliers required to maintain the constraints Φ.
- Let F = [F1, F2 … FNa]T represent external forces acting on the system.
- Let the kinetic energy of the system be
and the potential energy be
- Then the Lagrangian function
may be expressed as
Under these assumptions, the equations of motion for the system can be represented as:
The above equations are called the Euler-Lagrange representation of the equations of motion. In matrix form, equation (1) can be written as:
Equations (2.1) represent the force balance equations. The first term represents the inertia force, the second term represents the constraint forces and the third term the generalized external forces. Equations (2.1) is thus a restatement of Newton's Second Law of Motion. Equations (2.1) are differential equations that relate the time derivative of velocity (acceleration) to the external and internal forces acting on the system.
Equations (2.2) represent the kinematic differential equations in the system. These equations represent the equations of motion in first order form. To accomplish this, a new set of variables, u, the velocities are created. Velocities are defined as first-time derivatives of displacements. Equations (2.2) are also differential equations.
Equations (2.3) represent the algebraic constraints in the system. These come into existence because the equations were not formulated in terms of an independent coordinate set. The system has p=N-M degrees of freedom. The N coordinates therefore can be related to each other through M algebraic constraint equations.
Equations (2.4) represent the user-defined differential equations, specified using Control_Diff, Control_SISO, and Control_StateEqn elements. The user-defined states are denoted by x.
Equations (2) are a set of implicit, differential-algebraic equations (DAE). Let Z = [u, q, λ, x]T. Equations (2) can be represented in compressed notation as:
By differentiating equations (2.1) once and equations (2.3) three times, you can convert equations (3) to a set of Ordinary Differential Equations (ODE) of the form:
The index of a DAE is defined as the number of times the constraints are to be differentiated in order to convert the DAE to a set of ODE. Since three time differentiations of the constraints (2.3) are needed to arrive at the ODE form represented by equations (4), the index of the DAE is said to be 3. Index-3 DAE are also characterized by the fact that the matrix
A numerical solution of equations (2) or (3) requires specialized DAE integrators. These methods share the basic concept that accuracies in {u}, {q} and {λ} are controlled to different levels. One common approach (Index-3) is to ignore local integration error in {u} and {λ} and monitor local integration error in {q} only. Index-3 solutions thus tend to be less accurate, but very fast. If extremely accurate solutions are required, an alternative approach for the solution is preferred.
- Numerical Integration of the Equations of Motion Using
Stiffly-stable IntegratorsThe numerical integration of the equations is performed by the chosen integrator. Three stiffly-stable integrators are available today:
- VSTIFF, MSTIFF, and DSTIFF
Regardless of the integrator choice, the following three key operations are required to take a step.
a) Predict
The purpose of the predictor is to provide a good initial guess for the corrector. The predictor fits a polynomial through the previously calculated solution points. It then extrapolates the polynomial to the new value of time to "predict" the solution.
Figure 5. The PredictorThe image above shows how the predictor in DSTIFF works. Tn is the current time, and the integrator is predicting the value at tn+1. The predictor polynomial is shown in black. The extrapolation is shown in brick red. The predictor simply extrapolates past values; it does not solve the equations of motion. The order of the integrator defines the number of past values to take. In Figure 5, the order of the integrator is three, so three past values, starting from tn, are considered.
DSTIFF uses Newton Divided Differences to create an interpolating polynomial. This polynomial has the form:
The quantities [ Zn,Zn-1 ], [ Zn,Zn-1,Zn-2 ], etc. represent divided differences of the state Zn.
VSTIFF and MSTIFF use a slightly different scheme. An integrator of order K at time = tn has available to it K orders of derivatives. The integrator simply uses a Taylor's series expansion of the states Z to predict a solution at time = tn+1. This is shown in equation 8 below.
h = tn+1 - tn is the step size.
b) Correct
The purpose of the corrector is to refine the predicted so it satisfies the equations of motion:- Equation (3) for the DAE-Index 3 formulation
Both stiff and non-stiff integrators use correctors; however, the techniques employed in the corrector differ between the two. For the Index-3 DAE formulation, DSTIFF uses a modified Newton-Raphson (N-R) method to ensure the solution satisfies the equations of motion. For more information on Newton-Raphson, please refer to the discussion in DebugOutput. To employ this method, the DAE needs to be converted to a set of nonlinear, algebraic difference equations. This transformation is explained below.
The general integration formula for stiff integrators is:
In equation (9):- h is the step size being attempted and k is the order of the integrator.
- αj, β0 are coefficients defined by the integrator. These are
dependent on the method being used: VSTIFF, MSTIFF or
DSTIFF.
The integration formulae converts the system of DAE's to a set of non-linear algebraic equations (NLAE) that N-R (the first phase of the corrector) can solve.
The corrector goal may be stated more precisely as:
- Given a predicted value
Zn+1(p)
that is determined by the predictor, find a corrected value
Zn+1(c) that satisfies the
equations of motion (equations 3 or 7).
Using a first order Taylor's series expansion of G() about the predicted value, you obtain,
Define:
Then:
From (9) we get:
Substituting (12) into (11), we get the corrector relationship:The matrix [J] is called the Jacobian matrix of the equations of motion. From (13), a corrector iteration sequence is defined as shown in the figure below. At the heart of the process is the Newton-Raphson method of solving non-linear algebraic equations.
Figure 6. Corrector iteration sequence in DSTIFF.The error norm is calculated in DDWNRM(…) as shown in the figure below.
Figure 7. The calculation of the error norm in DDWNRM (…).In the figure above:- RTOL[i] (relative tolerance) and ATOL[i] (absolute tolerance) are calculated from the error tolerance, INTEGR_TOL, specified in the PARAM_TRANSIENT block of the input file and a scale factor that is dependent on the variable type: RTOL[i] = ATOL[i] = INTEGR_TOL * SCALE[i].
- SCALE[i] is calculated from the attributes
VEL_TOL_FACTOR and
DAE_ALG_TOL_FACTOR specified in the
file and is explained further in the table below. The
various states in Z are scaled as follows:
Table 1. Scale values for the solution vector. State type Attribute Default Value for Scale Displacement 1.0 Differential States 1.0 Velocity VEL_TOL_FACTOR 1000.0 Lagrange Multipliers DAE_ALG_TOL_FACTOR 1000.0 For displacement and user-defined differential states:
- RTOL[i] = ATOL[i] = INTEGR_TOL
For velocity states:
- RTOL[i] = ATOL[i] = VEL_TOL_FACTOR*INTEGR_TOL
For Lagrange multiplier state:
- RTOL[i] = ATOL[i] = DAE_ALG_TOL_FACTOR*INTEGR_TOL
b) Estimate local truncation error
The corrector ensures that the solution satisfies the equations of motion (EOM) (for example, the EOM are consistent), but it does not ensure accuracy. The next step in the process is calculating the integration error in the step to estimate accuracy, since it is possible that the corrected solution is not the "true" solution; rather, the prediction may have been poor, and the corrector may have found a solution that is no longer consistent with the model's initial conditions. In other words, your result may have "jumped" to a different solution in the solution manifold, albeit consistent with the EOM. The error calculation is shown in the figure below. Ck is a step-size error coefficient that is calculated by the integrator.
Figure 8. Local truncation error test. - VSTIFF, MSTIFF, and DSTIFF
- Why are stiff integrators so effective for highly-damped
problems?
To understand why, consider the following test problem:
The true solution for this problem is:
The Backward Euler is a first order stiff integrator. It has the form:
Applying (16) to equation (14) yields:
As
for any positive value of h. Backward Euler is stable for any value of h. The larger the step-size h is, the faster yn+1 will converge to zero.
In contrast, when the same calculations are done with the Forward Euler integrator, a non-stiff integrator of order 1, the following results are seen. The Forward Euler has the form:
Applying (18) to equation (14) yields:
Equation (19) states that for the Forward Euler:
Asonly when
Consider a highly damped problem, l=104 in equation (14).
- Equation (20) implies that the Forward Euler will yield the stable results only when the step size h < 2 x 10-4.
- Equation (17c) implies that the Backward Euler will yield stable
results for any step h.
This is why stiff integrators are so effective for damped problems.
- My model fails due to integrator failures. How can I diagnose
this issue and fix it?
Multi-step integrators like DSTIFF and VSTIFF estimate the local error at each step by computing the difference between the predicted and the corrected value of the solution, and scaling it by an "error coefficient" that is calculated by the integrator. A bad prediction can therefore cause an integration error.
Predictions can be inaccurate for two reasons:- There is a discontinuous motion input in the system.
- There is an almost discontinuous force in the system.
The effect of such modeling is shown in figures 10a and 10b below.
Figure 9. Discontinuities are the root cause of integration failures.Discontinuities such as those shown above can be caused by function expressions or user subroutines that use IF-THEN-ELSE logic carelessly. Modeling elements that should be examined for discontinuities or sharp changes include:- Forces
- Variables
- User Differential Equations
- General State Equations
It is a good idea to replace IF-THEN-ELSE logic with smooth STEP functions. Also, use the MotionSolve XML statement:
<DebugOutput> SwitchOn="True" </DebugOutput>
to enable detailed Newton-Raphson iteration output. By looking at this output, you can usually backtrack to the modeling elements that are likely causing the failure.
The normal fix for such situations is the following:
- Make sure stiffness/damping coefficients are realistic.
- Make sure masses and inertias are physically meaningful.
- Identify and eliminate discontinuity in modeling element[s].
- Avoid very steep STEP functions.
- Temporarily loosen INTEGR_TOL to understand true cause.
- Have my results converged? That is, have they stopped
changing with the error tolerance?We recommend that you perform a convergence study to ensure that the results you get from the integrator have stopped changing (are converged). Since the integrator is approximating an exact solution, it is possible that allowing too much error in the integrator causes the integrator to provide a different result than if the error tolerance is tighter (smaller). There are a range of settings to allow you to tune the integrator as desired, but the few to start investigating first are the following:
- integr_tol
- h_max
- vel_tol_factor for DSTIFF, which requires SI1 and via the dae_index parameter)
You may get converged results in different ways, but below is one example that may work for you:- Pick the channels of data you are interested in the model (displacements, forces, and so on).
- Pick the integrator - what does it perform error control on? (displacements, velocities, differential states).
- Reduce the error until the states that the integrator controls converge. Then, take the largest error that gives the converged result.
- If you're still interested in the states that the integrator does not control with error tolerance, reduce the integrator maximum step size (h_max) until those states converge. Then, use the largest h_max that gives the converged results.
- If the simulation fails, you can loosen (increase) error tolerance and control accuracy with the integrator maximum step size (h_max) to try to get past the problem. This will likely take more time than for a variable-step integrator, so use as a last resort.
- Many other integrator settings are also available, so consider exploring other options that may be applicable to your model.
- Relative Comparison of the Various Formulation
ApproachesThe table below summarizes the relative strengths of the different DAE approaches. The following criteria are used to characterize the different approaches:
- Accuracy
- Measures the integration error (calculated as shown in Figure Figure 5) that is accumulated in the solution array.
- Speed
- Measures the relative CPU time commonly seen for the different approaches. This is highly model-dependent, and reflects our experiences to data in testing the various approaches.
- Handling Discontinuities
- Measures the ability of the formulation to deal with a sharp
corner or a discontinuity in a system input (Motion or
Force). Discontinuities and sharp corners
(non-differentiability) should be avoided in models.
- Consistency
- Measures how well the solution satisfies the constraints Φ and its first and second time derivatives.
- Tracking High Frequencies
- Measures how well high frequencies in a system are tracked.
- Numerical Damping
- Measures the numerical damping applied because of the implementation of a certain index formulation. In general, high numerical damping leads to faster and more robust solutions, though at the expense of some accuracy.
- Robustness
- The default DE formulation is Index-3. We recommend that you use the Index-3 formulation first, and consider switching to other formulations only if a solution is found that lacks in the criteria shown above.
Note: The table below contains subjective information, and should therefore be regarded as a general guideline, not an absolute recommendation.Table 2. Relative merits of the different equation formulations. I-3 SI-1 ODE (SI-0) ABAM Accuracy Medium High High High Speed High Medium Low High / Very Low*
Handling Discontinuities High Low Low High Consistency Low High High High Tracking High Frequencies Low High High High Numerical Damping High Low Low Low Robustness High Medium Medium High (*For ABAM, Speed is high for non-stiff and very low for stiff problems)
- It is almost always not a good idea to increase DAE_CONSTR_TOL above 0.001 mm. This tolerance governs the minimum solution accuracy for the kinematic constraints in the system specified in the length units of the model. When DAE_CONSTR_TOL is large (greater than 0.001 mm), the system constraints can be only loosely satisfied. In addition to creating inaccurate answers, errors in constraint satisfaction can also cause the numerical solution to become unstable and even cause failures.
- The dae_jacob_eval and
dae_jacob_init both control when the Jacobian is
evaluated during the corrector iterations. The key difference between the two is
in the way they affect the Jacobian evaluation frequency.Let M be the iteration counter for the Newton Raphson iterations. Note that his index is implemented as a 0-index, meaning that it starts from 0. The Jacobian is re-evaluated whenever either or both of the following conditions are true:
- MOD(M, dae_jacob_eval) = 0
- M < dae_jacob_init
The following tables illustrate this better
Corrector iteration counter (M) dae_jacob_eval = 2 dae_jacob_init = 2 New Jacobian? MOD (M, 2) = 0? M < 2? 0 Yes Yes Yes 1 No Yes Yes 2 Yes No Yes 3 No No No 4 Yes No Yes Corrector iteration counter (M) dae_jacob_eval = 3 dae_jacob_init = 2 New Jacobian? MOD (M, 3) = 0? M < 2? 0 Yes Yes Yes 1 No Yes Yes 2 No No No 3 Yes No Yes 4 No No No 5 No No No 6 Yes No Yes 7 No No No - ReferencesVSTIFF:
- "VODE, a Variable-Coefficient ODE Solver", P. N. Brown, G. D. Byrne, and A. C. Hindmarsh. SIAM J. Sci. Stat. Comput., 10, pp1038-1051, 1989.
- "A Poly-algorithm for the Numerical Solution of Ordinary Differential Equations," G. D. Byrne and A. C. Hindmarsh, ACM Trans. Math. Software, 1 (1975), pp. 71-96.
- "EPISODE: An Effective Package for the Integration of Systems of Ordinary Differential Equations," A. C. Hindmarsh and G. D. Byrne, LLNL Report UCID-30112, Rev. 1, April 1977
- "ODEPACK, a Systematized Collection of ODE Solvers," in Scientific Computing, A. C. Hindmarsh; R. S. Stepleman et al., eds., North-Holland, Amsterdam, 1983, pp. 55-64.
DSTIFF:- "The Numerical Solution of Initial Value Problems in Differential-Algebraic Equations", L. Petzold, K. E. Brenan and S. L. Campbell, Elsevier Science Publishing Co., (1989) , second edition, SIAM Classics Series, 1996.
- "Consistent Initial Condition Calculation for Differential-Algebraic Systems ", P. N. Brown, A. C. Hindmarsh, and L. R. Petzold, SIAM J. Sci. Comp. 19 (1998), pp. 1495-1512.
MSTIFF:- "The Integration Of Stiff Initial Value Problems In O.D.E.S Using Modified Extended Backward Differentiation Formulae", J. Cash, Comp. and Maths. with Applics., 9:645-657, 1983.
- "The Integration Of Stiff Initial Value Problems In O.D.E.S Using Modified Extended Backward Differentiation Formulae", J.R. Cash, Comp. And Maths. With Applics., 9, 645-657, (1983).
- "Stable Recursions With Applications To The Numerical Solution Of Stiff Systems", J.R. Cash, Academic Press.(1979)
- "Ordinary Differential Equation System Solver", A.C. Hindmarsh, Gear, C.W., Ucid-30001 Rev. 3, Lawrence Livermore Laboratory, Livermore, Ca 94550, Dec. 1974.
- "An Mebdf Code For Stiff Initial Value Problems", J.R. Cash And S.
Considine, ACM Transactions On Mathematical Software, 1992.
ABAM:
- "Computer Solution of Ordinary Differential Equations", Lawrence F. Shampine and Marilyn K. Gordon, W.H.Freeman & Co Ltd, June 1975.
