/INIBRI/STRS_F
Block Format Keyword Describes the initial state (full stress in local system, values for each integration point) for a brick.
| /INIBRI/STRS_F/unit_ID | |||||||||
| brick_ID | Nb_integr | Isolnod | Isolid |
| Eint | |||||||||
| Eint | |||||||||
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| brick_ID | Element
identifier. (Integer) |
| Nb_integr | Number of integration
points. It corresponds to the property definition of this element. (Integer) |
| Isolnod | Number of nodes of solid
| Isolid | Solid elements
formulation It corresponds to the solid elements formulation of in property definition of this element. (Integer) |
| Plastic
strain (Real) |
| Stress (Real) |
| Stress (Real) |
| Stress (Real) |
| Shear
stress (Real) |
| Shear
stress (Real) |
| Shear
stress (Real) |
| Eint | Internal energy of solid
element (Real) |
| Volumetric
mass (Real) |
- The initial state for brick may be defined by more than one block.
- If Nb_integr
> 1, the optional continuation lines must be repeated for each integration
point, if Keyword2 = STRS_F and 8-node
solid element with 1 or 8 integration point.
Format Line 4; Format Line 5; Format Line 6
- If Nb_integr
> 1, the optional continuation lines have to be repeated for each integration point,
if Keyword2 = STRS_FGLO and 16-node or 20-node
solid elements, 8-node HA8 elements, 8-node HSEPH elements, 6-node PA6 elements;
8-node HSEPH elements, 6-node PA6 elements, 10-nodes tetrahedron or Pentahedron 6
nodes.
Format Line 3; Format Line 4; Format Line 5
- Using
/INIBRI/STRS_F, you are assuming there is no density of
the deformed elements. Before the first cycle, Radioss will check consistency of the input stress tensor with material data
(stiffness and density):
(1) Where,- Density defined in the Starter file
- Density in the state file
If the stress is not fulfilled, then Radioss will correct the diagonal entry of the stress tensor:(2) ( =1,2,3)
