/INISTA
Block Format Keyword Describes the initial state file.
/INISTA | |||||||||
Isrtynnn | |||||||||
Ibal | IoutyyFMT | Ioutynnn |
Isrtynnn | Complete name of the
initial state file. (left tabulated - Character, maximum 100 characters) |
Ibal | Initial balance flag.
(Integer) |
IoutyyFMT |
(Integer) |
Ioutynnn |
(Integer) |
- The initial state for shells and
solids: density (only solid), internal energy (only solid), plastic strains (only
solid), stresses, strains, thickness, hourglass and forces is read in the output
file Isrty000: RunnameYnnn (if
Irootyy = 2 in /IOFLAG option) or
Runname_run#.sty (if Irootyy ≠ 2 in
/IOFLAG option).
The file Isrty000 is also compulsory to define the initial model. Initial states are only available for bricks (solids) and shells. For output file formats, see ASCII Output File (STY-File).
- If using /INISTA with User's Material Law, users variables should be initialized with the /OUTP/SOLID/USERS/FULL option in the STY-File.
- If Ibal = 2, a new initial balance of the model structure is recomputed.
