/INIBRI/FILL
Block Format Keyword Describes the filling percentage for a brick.
/INIBRI/FILL/unit_ID | |||||||||
brick_ID | value |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
brick_ID | Element
identifier (Integer) |
value | Date
value (Real) |
- The initial state for brick may be defined by more than one block.
- The filling percentage is used for scaling the mass of the element, as well as its stiffness and internal forces.
- This option is compatible with every solid element formulation.
- The stiffness used for contact TYPE2 (penalty formulations), 5, 7, 10, 11, 19, 20 and 24 is scaled accordingly.
- The filling percentage can be output with /ANIM/BRICK/FILL.
