/INIBRI/ENER
Block Format Keyword Describes the initial state for a brick
/INIBRI/ENER/unit_ID | |||||||||
brick_ID | value |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
brick_ID | Element
identifier. (Integer) |
value | Date
value. (Real) |
- The internal energy is expressed by volume unit.
- The initial state for brick may be defined by more than one block.
