Sort the list of nodes by a node property.
The list of nodes can be sorted by any of the node properties except:
Click the name of a column to toggle between sorting the results in ascending
or descending order.
A
![](../../images/icons/sort_ascending.png)
above the name of the column indicates that the
results are sorted in ascending order. A
![](../../images/icons/sort_descending.png)
indicates that the results are sorted in descending
order.
