Add a Node Property to the Node Detail View
Enable the display of a node property by adding it to the Node Detail view.
The Node Detail view displays the HPC cluster's nodes. By default, each node is represented by a row containing the following information:
  • the name of the node
  • the state of the node
  • number of CPUs being used / total number of CPUs present on the node
  • amount of memory being used / total memory present on the node
  • a comma separated list of the jobs running on the node in the format jobid/cpu_no where cpu_no identifies the CPU that is being used by the job. CPUs are numbered from 0 to n.
  • comments added by the WLM administrator or the WLM itself about the node
You can view other node properties by enabling their display.
  1. Click located in the upper right-hand corner of the web page.
  2. Enable the check box next to the name of the node property.
    Tip: You can remove a node property from the list by disabling its check box or you can reset the display back to the default node properties by clicking the Reset link.
    The node property is added as a column to the Node Detail view.
  3. Click outside the Settings dialog box to close it.
