Export Node Details to a CSV File
Export node data to a Comma Separated Values (CSV) file for further inspection and analysis.
Drill-down to get detailed information about the HPC cluster's nodes or nodes attached to a queue.
Columns displayed on the Node Detail View are exported to a CSV file for any nodes that meet the current filter and search criteria. For example, if there are seven pages of nodes that match the filter and search criteria, then all seven pages of nodes are exported to the CSV file.
Tip: Add a node property to the Node Detail View to include the column in the data that is exported to the CSV file.
Click located in the upper right-hand corner of the web page.
Once the CSV file is created and downloaded, the CSV file can be opened.
