Set Face Faceting Parameters
Set Face Faceting Parameters for analysis in SimSolid Cloud.
In the icon palette, click
Settings.
Click the Onshape tab.
- In the Resolution menu from geometry import settings, choose, Standard, Enhanced, or Fine. The values will automatically populate the Angular deviation and Chordal deviation fields.
- In the Resolution menu, choose Custom. Then, enter the desired values in the Angular deviation and Chordal deviation fields.
- Click Save.
