/XELEM
Block Format Keyword Describes the multi-strand element. It could be use with /PROP/TYPE28 (NSTRAND), and it could be used for belt modelization by taking nodes upon the dummy.
/XELEM/part_ID | |||||||||
elem_ID | grnd_ID |
part_ID | Part identifier of the
multi-strand (Integer, maximum 10 digits) |
elem_ID | Element
identifier (Integer) |
grnd_ID | Ordered node group
- The ID must be unique in each element family, but it is advised for each element type to have a unique element ID in the global model.
- Nodes define a line from the first to the final node of the group.
- The grnd_ID must be defined with the keyword /GRNOD.
- The grnd_ID input is obligatory. The element will only be composed of the nodes belonging to a node group.
