/VEL/ALE (Obsolete)
Engine Keyword With ALE links on grid velocities, given nodes are linked to the given main grid velocities. You can specify direction or a combination of directions.
/VEL/ALE/Keyword3/Iform/Keyword5
M1 , M2
ID1 , ..., IDn
| Data | Description | SI Unit Example |
| Keyword3 | A combination of X, Y,
and Z: X, Y, Z, XY, XZ, YZ, YX, ZX, ZY, XYZ, YXZ, . . . |
| Option | Formulation flag
(Integer) = 0 (linear):
= 1 (maximum): WN1 = WM1 if |WM1| > |WM2| WN1 = WM2 if |WM1| < |WM2| = -1 (minimum): WN1 = WM1 if |WM1| < |WM2| WN1 = WM2 if |WM1| > |WM2| |
| Keyword5 | «GRNOD» or «NODES» defines the way of providing secondary nodes | |
| M1 | First mainr node number | |
| M2 | Second main node number | |
| IDi | Secondary nodes identifiers or node group identifier (depending on Keyword5). 2 |
- This card is obsolete. It is replaced by /ALE/LINK/VEL.
- Using Keyword5=«GRNOD» requires a single identifier ID1.
- Using formulation Iform=0 requires an ordered node list. Using Iform=0 with Keyword5=«GRNOD» also requires an unsortable node group (/GRNOD/NODENS).
