/ANIM/CUT/3 (Obsolete)
Engine Keyword Defines a section cut on a deformed geometry using three nodes.
/ANIM/CUT/3
Name
N1, N2, and N3
| Data | Description | SI Unit Example |
| Name | Name of the section cut | |
| N1, N2 and N3 | Nodes |
- A plane cut is defined in the deformed geometry using three nodes N1, N2 and N3
- When using the mass option /ANIM/MASS, the balance displayed in the post-processing is the volumetric flux.
- This keyword is not available for SPMD version.
