Engine Keyword Enables you to modify coefficients for standard
upwind formulation previously defined from Starter Input or from previous run.
/UPWIND
1
2
3
| Field |
Content |
SI Unit Example |
1 |
Upwind coefficient on ALE
momentum transport 2
Default = 1.0 (Real)
0 ≤
1 ≤ 1 (full upwind)
2 |
other ALE transports (mass, energy ...) Default = 1.0
(Real)
0 ≤
2 ≤ 1 (full upwind)
3 |
Upwind coefficient for wet
area 3 Default = 1.0
(Real)
0 ≤
3 ≤ 1
- This option can be used with ALE or
Eulerian modeling.
- This
coefficient has no influence if Taylor Galerkine
(/UPWM/TG (Obsolete)) or Streamline Upwind
(/UPWM/SUPG (Obsolete)) formulation is
defined, except for multi-material LAW51 (/MAT/LAW51 (MULTIMAT)).
is a coefficient for multi-phase law.
is only available for multi-material LAW51
(/MAT/MULTIMAT).
=1 is stable, but diffusive.
=0 is less diffusive, but might be
unstable.
