/DT/GLOB/Iflag
Engine Keyword Global time step estimation, enables setting the time step to a higher value than the usual elementary or nodal time step.
/DT/GLOB/Iflag
If Iflag =1, insert the next line
Tol_GTS Ncycles
| Data | Description | SI Unit Example |
| Iflag | Number of additional
(optional) cards.
| Scale factor on
critical time stop. Default = 0.9 |
| Tol_GTS | Tolerance for GTS
convergence. Default = 10-3 |
| Ncycles | Frequency (number of
cycles) for global time step estimation. Default = 20 |
- If
/DT/GLOB is used with /DT/NODA, the
simulation begins with nodal time step and global time step follows.
If /DT/GLOB is used alone or with /DT, the starting time step is element type step followed by global time step.
- If Iflag =1, the tolerance for
GTS convergence, Tol_GTS and the frequency
Ncycles for global time step must be entered.
If Iflag =0 or is blank, default values for Tol_GTS and Ncycles are used.
- The Global Time
Step option is available for the following features:
- Solid elements: /TETRA4, /TETRA10, hexa with the flags below
- /PROP/SOLID: Isolid = 1 (Belytschko), 14 (HA8), 17 (H8C), 24 (HEPH) and 16 (20-noded)
- Shell elements: Ishell = 1 (Belytschko-Tsay), 12 (Batoz), and 24 (HEPH)
- Truss element
- Beam element
- Contact interfaces: TYPE7, TYPE24 (without edge-to-edge option), and TYPE2 with Spotflag= 25 and 27.
- In most cases, default values are sufficient to ensure a stable run, however in cases where the global stiffness varies frequently due to oscillating contact conditions, it is recommended to increase the convergence tolerance, Tol_GTS= 0.05 and reduce the scale factor on time step, = 0.8.
